av jetski » 13 augusti 2011, 19:27
Nu hara jag fått hem min nya jetski !
Den är av märket Coimposit Tech och är gjord av 100% Carbonefiber.
Skrovets vikt är ändast 29kg !!!!!!!!!!!!!!!!!!
Det siter en Dasa 800cc motor i denna jetski med Solas magnum pump.
Ny så kostade skrovet 15000euro och skrovet kommer ifrån 2008. Företaget tillverkade detta skrov mellan 2006 till 2009 innan de la ned tillverkningen.
Företaget som tillverkade denna jetski gör idag delar till Euro fihgter och till formulet F1 bilar.
Lite info ifrån tillverkarens hemsida
Compositech now Applying Expertise to Personal Water Craft for Jet-Ski Hulls - March 2006
French company Compositech, which is experienced in manufacturing composite parts for high performance automobiles and industrial applications, is now applying its expertise to personal water craft for jet-ski hulls.
Compositech has achieved dramatic reductions in the weight of their latest jet-ski hull design by the use of ACG's LTM® and VTM® composite prepreg materials. Curing at temperatures as low as 40°C, ACG's materials are clean and simple to lay-up, allow for greater freedom of design and ultimately create lightweight structures of great strength and stability.
By their innovative use of Formula One manufacturing methods and carbon composite materials Compositech has designed and built a hull that is almost 50% less than their previous 56kg design. This dramatic weight saving has allowed an equally dramatic improvement in performance as demonstrated by their world renowned pilots Pierre Maixent and Gil Beurnier. They praise its performance characteristics while acknowledging that some time is required to adapt to its lightness and precise manoeuvrability which make it ideal for the regular freestyle competitor.
The use of carbon composite materials has allowed the Compositech design to achieve a more streamlined shape to the top of the hull, the premier modification being that the dashboard is an integral part of the carbon structure, improving the visibility and control of the jet-ski.
- Bilagor
- DSC00590_mini.jpg (26.57 KiB) Visad 19908 gånger
- DSC00588_mini.jpg (35.25 KiB) Visad 19908 gånger
- DSC00585_mini.jpg (32.78 KiB) Visad 19908 gånger
- DSC00583_mini.jpg (29.8 KiB) Visad 19908 gånger
jetski 21 september 2011, 08:30, redigerad totalt 2 gånger.
